jeffkersey
I did not build my RV7a. I purchased it flying. There were 2 layers of wide clear tape between the trailing edge of the wing and the leading edge of the leading, pivoting, bevel of the flap. Sunlight and use has flaked off and worn through most of the first layer and is starting to work on the second layer. I want to prepare for my next condition inspection due in March.
What is the process to remove the flap. Big Hassle? What is the best replacement type/brand/size? I have seen some "metal" tape on other RVs that look more robust that clear tape? Who is the best supplier for the tape?
Thanks for your help...
