First Flight Answers
A very hearty congratulations on your First Flight, Jean-Pierre!!!
MES FELICITIONS POUR TON PREMIER VOL.
(BTW &FYI Ma femme est Francaise....)
I think it was the most exciting thing I ever did.
Robert Bogash
N737G
Sounds like you may have some problems getting your plane back after the 5 hours have been flown off. Congratulations J-P.
Jean-Pierre
Bonjour and congratulations.
Must be a great feeling, and the pilot reported so enthusiastically about the outcome ofsuch a quality build.
Have you any ideawhythe push to talk causedthe EGT readings to peak?
John
Jean-Pierre
John
John, thanks. I remember someone mentioning he had the same problem but I did not have time to investigate or talk to VANs. I just suspect that it might be related to the conversion harness I am using as I got the wiring for the D100 and had to use the Skyview. It looks like a grounding issue but If anyone has suggestions, you are welcome.
If your PTT switch causes your EGTs digits to go crazy, contact Dynon. I just sent my EMS-220 into Dynon for the factory CB mod to hopefully take care of this problem.
