BillL
I bought an in process RV7 that had been prepared for a carb with a gascolator installed. I decided for fuel injection over the carb. It is time to install the high pressure fuel pump for the FI. I have a Vans sourced IO-360 M1B standing by. I have looked at drawing OP32 that shows a different firewall penetration point for injected fuel supply.
So . . it seems there are three options:
1. Remove gascolator, plug the hole in firewall and install the patch and hole per OP-32.
(this avoids special fuel hose and routing. )
2. Remove gascolator and install bulkhead fitting and run fuel hose over to that point on the firewall.
( can the hose be routed here?)
3. Leave gascolator in place and connect to engine.
(This has more points to leak, more pressure drop when pump is off, and more opportunity for heat collection with the additional surface area and residence time of fuel in the gascolator. Not fond of possibility of fuel delivery issues and vapor lock)
Who has done any of these and what were your results? Please Help!!
