I have some Champion fine wire plugs that don't exhibit any outward trouble signs. Engine starts easy, doesn't miss, can't tell any performance loss, and they look good visually. Question: After some minor cleaning I did a resistance check (repeatly) and confirmed some that read in excess of 9000 ohms. Replace? Keep running them? Is there a place to buy rebuild parts for the internals? Any suggestions? These plugs are very expensive and I'd like to save some money. Are the internal (removeable) resistors the same value for massives and fine wires? Are the resistors available for a plug rebuild? What is the consequence of exchanging the high resistance (bad) resistor from the fine wire plug with a good resistor from a massive? Anyone tried doing this?
