Installed the Filtered air box today and getting ready to form the transition from snorkel to FAB. I added 1/8? washers between FAB and servo as per instructions to accommodate for engine sag down the road. When adding the washers, I had to raise the bend in the front of the top plate to line up with top of snorkel. It looked like quite a bit of change. Plus, I?m concerned It won?t be aligned properly until that sag occurs.
Ran across this thread with same concern. Notice his pic of the gap it created. One builder didn?t worry about it and had no sag. http://www.vansairforce.com/community/showthread.php?t=71583
So, my question is, should I plan for 1/8? sag and use the washers? If yes, do I need to do anything for phase 1 flights before sag has had time to occur?
