Why?I’m finally installing the fiberglass tips on the vertical and horizontal stabilizers. My question is what are most builders doing in terms of filling the ends of the control surfaces? Fill everything? Both ends of the elevators? What about the ends of the flaps, ailerons etc?
Why not build the plane as per the plans, it is usually the safest thing to do.I don’t understand what exactly is being filled. Does anyone have a picture?
Exact same description of filler plugs I removed from RV6 I described above. I hope you did a better job glassing them in compared to that guy. He was flight moments away from having a bad day…I used 1/2" foam board (Owens-Corning), and West Systems epoxy+milled fibers to fill and attach to the inset rib/cavities on the rudder counter balance "arm", the elevator counter balance arms, and inboard ends.
Here's a good video showing how one builder filled the ends.I’m finally installing the fiberglass tips on the vertical and horizontal stabilizers. My question is what are most builders doing in terms of filling the ends of the control surfaces? Fill everything? Both ends of the elevators? What about the ends of the flaps, ailerons etc?
Plus, it's entirely possible that there may be future maintenance issues that nobody knows about today, but that you ultimately make a lot harder by doing stuff like that. SB-00036 comes to mind. It would be pretty much impossible to do that service bulletin with the ends of the horizontal stab faired in.
Hey Carl- I get that you can drill a hole to get a bore scope in there, but if the recurring inspection ever reveals spar cracks it seems like a guy would have a heck of a time complying with the subsequent steps.I filled in control surface end ribs on all my builds. This is strictly cosmetic, no aerodynamic gain at all.
I do add drain paths.
For the new RV-8 the HS Service Bulletin came out a couple of weeks after I finished it. The photo shows the 3/8” hole that I use to insert a borescope to do the SB. A piece of aluminum tape covers the hole until the next inspection.
Carl
Inspection isn't a problem if you have a small enough borescopeHey Carl- I get that you can drill a hole to get a bore scope in there, but if the recurring inspection ever reveals spar cracks it seems like a guy would have a heck of a time complying with the subsequent steps.
It was just an example off the top of my head.
