Thinking of using Fiberfrax on cowling near exhaust pipes.
Has anyone used this material and if so, what thickness is recommended 1/16" or 1/8"?
I am thinking of adding 1/8" to my firewall on a new build. It says 2000f temp. anyone used it in lieu of some of the other stuff tested by Dan H.? I don't recall him testing fiberfax.
Jim RV-6
dues paid
I put 1/16" Fiberfrax on the firewall covered with stainless steel foil, seamed with Al tape; and the same 1/16" on my exhaust tunnel covered with .012 Titanium sheet seemed with Firebarrier 2000. I believe Dans test showed it does its job but does outgas when flamed, hence his recommendation was only on the engine side......thickness would be your call. I dont know any property differences.
