OK Rocket builders, here’s a question for you - I have gone through every version of the build manual on the Rocket site, and they all caution not to drill the rear canopy track to the fuselage before fitting the canopy frame. Makes some sense. There was some moving around and adjusting while bending, cutting, and welding the frame. But now I’m done with all that, and getting ready to move on to the canopy - and can’t find a reference to “Now its OK to drill and bolt the track to the fuselage….” I’m not sure I can think of a reason not to at this point (the geometry is sort of fixed by the custom-fit frame)….but is there some reason I am going to regret drilling it now that I won’t find out until later?
FYI - I used the conduit bender technique on the front bow to get it where I wanted, then cut the rear bow and shaped it using a bending board before welding it back on. I’m pretty pleased at how the frame is moving on the track!
