Did I miss in the directions how to fill the hole that is created just under the leading edge where the f-1069 side skins are bent up to the bottom skin? If not, how did you guys fill this opening? Thanks,
Yeah it doesn’t get covered by the wing or the intersection fairing. I put a piece of aluminum tape over them but I’m at a place where I can complete a permanent fix. I’m guessing glass over it, just wanted to make sure I didn’t miss something that was actually called out to do. Thanks
I filled with 3m HS repair filler (a stronger and more structural bondo). scuff the inside well and apply bondo from inside with a generous overlap on skin to create a secure plug. Then shape the outside with sandpaper, blending into the skin surface. You could also use epoxy/flox. If you don't care about the cosemetics, you could fill it with silicone after paint to stop the air intrusion.
