DavidHarris
I see Antisplat Aero has 10% off right now (code "NEWYEAR" until Feb 15), and the EZ Oil Filter Drain caught my eye because I often make a mess dripping oil from the filter during an oil change.
You tap a sharp point of the drain into your filter, then connect compressed air, and it blows the oil out of the filter. Looks like a clever solution, and I'm happy with several other AntiSplat tools and mods.
Being less than an engine wiz, I'm looking for a bit of feedback on whether this might create any issues. If the engine is making metal and the filter has collected it, would I be blowing that metal back into the engine rather than detecting it? Any other problems with pressurizing the engine via the filter?
Thanks!
David
Thanks!
David
