Experience with the Lockwood Rotax 916 Package
I did the 25 hours in the last 15 days and I'm loving it. It has met all my expectations so far. Nothing has been overstated.
Sorry, I put this in a new thread and forgot to reply
How much longer did they need to make the nose of the plane to offset CG. Impossible to tell from pics, but looks like 18" or so to my eye
They moved the engine forward 14". This does not match the previous C of G, it places it in a new further forward location. As an example I can carry myself, 200lbs, my 185lb buddy, 100 lbs of luggage in the back and full fuel and I am in the center of the envelope. I am at an empty C of G of 76.4
Yes, I too was/am concerned about flutter and I asked Lockwood about that, but I just can't remember what we discussed. I do know that they apparently, along with Van's I believe (but don't quote me on that) have spin tested it, and it checked out well. My current understanding is that Vne is always a True Airspeed, but I could be wrong.
I'm also thinking about possible mountain wave gust/G loading at altitude & speed. In fact (save the negative comments), I'm even "considering" a chute since it makes my wife happy & we are talking about the bleeding edge here for experimental. Per Lockwood, there is a net 80 lbs of savings so it maybe would be a wash, but I have not looked into it yet, especially how it may impact the CG that they worked so hard to keep centered by extending that nose. Not to mention, this makes the costing math even worse, as in might as well just go buy a VL-3 or even a Sling, or a ...?
Thanks for the info on the 9a Sidewinder. I did see that, but that airframe work is a bridge too far for me to cross, as I will be at my patience and technical limits just with the firewall forward and panel stuff. I'm in S. Fl. close to Lockwood, so I asked if they would just do a conversion for me, but the said they don't currently have the resources, but may one day consider that as an option.
RV9A for sale with sidewinder?? Who, where?
I finally got my IPC in N472RV and was able to test at FL230. The plane flys well at altitude and is turning out to be a great cross country platform.
Nice, I'm sure the Delta Hawk would perform at similar levels of performance. Being able to produce less than 130 hp in a IO390 at altitude feels very lethargic!
Yes, I will be doing the testing of the heater core system but thought you may have found something else having been at 23,000ft.
I use an electric snowmobilers jacket with 12 volt supply in my 9A at altitude in the hard winter, since the exhaust heat muff is fairly anemic. I'm happy to hear there will be a coolant loop - that should give plenty heat. Is that going to be part of the kit going forward or just part of the owner installation?
This is a great idea. I'm toying with adding a second heat muff in series, or designing one that can fit a longer pipe (#2) with slight bends, as I also like to fly high in cold weather. Although having two cracks in the canopy gives me some pause for thermal shocks.
