I'm real reluctant to thin any resin with acetone. I think you are asking for trouble. no matter what vans says. just my opinion. I like what dan did. thanks for the idea I'm gonna steal it lol.
Erik
The inside of the cowl should be sealed. For the most part, over a period of time I brushed on epoxy that was left over from other jobs. Not only does this seal the inside of the cowl making wiping away grease and grime easier, but even more importantly, gives heat foil a much improved surface to better adhere to.Did you leave the cowling inside as is or did you put a thinned coat of epoxy in order to keep it clean. As rough and porous as it is, it sure does seem like it will collect oil and dirt over time.
The thinned epoxy runs into the pin holes better, that's all. No real reason.This particular Dan doesn't much like ad-hoc chemistry in the field.
Here's the question. Is there some good reason to thin it?
The thinned epoxy runs into the pin holes better, that's all. No real reason. the odd part was that it took a long time to harden but in checking with a Chemist friend that I used to work with, he looked up the chemical makeup and give it his blessing. Once it hardens you can't tell any difference between this epoxy and any other. That said, I wouldn't use it any place you need structural strength.
I also coated once with thinned epoxy, then painted with high heat paint and then coated that with more thinned epoxy.
Looks good and is tough but time will tell if it will work long term.
I painted it just to cover up that darn pink inside.
What was Van's thinking with that pink?????
Couldnt you use a 'wet' micro resin to get the same result as thinning it with Acetone?
If you want easier spreading, another way to skin that cat is heat. You brush on a coat of un thinned resin, and hit it with a hair dryer, it will flow out pretty well, a little squeegee work will spread it evenly.
Thanks Guys, great discussion.
Guy/Tom, where did you get the high temp paint from?
.... west systems, slow hardner and I store the epoxy in the frig so it was cold to start with.
....plus the heat expands the air in the voids. When it cools it pulls some resin into the voids.
These got a single brushed coat of epoxy, a light scuff when cured, then epoxy primer and a cross coat of two-part single stage.
Disclaimer...I do not recommend, and would never myself use, any chemical to thin epoxy when doing any glass lay-up that would be considered structural.
(Hijacking thread) Dan, do you mind sharing which primer and which two-part single stage?
Lars, there are many good choices. I prefer major players; PPG, Sherwin Williams, Akzo Nobel, etc. I don't mix and match brands; again no ad-hoc chemistry.
This airplane is all PPG, so DPLF epoxy primer is first. K36 primer-surfacer is next if you need bulk surface fill for blocking. If you don't need the fill, go directly to topcoat. The topcoat white in the cowl photo is PPG's cheap Shopline two-part single stage. The outside will get a two-stage base/clear, but that's only because I'm crazy.
"Two-part" means A+B, paint and hardener. "Single stage" means no clear coat; the color coat is the final finish.
The other majors all have similar products. About the best reason to pick one over the other is your local paint shop, who probably handles just one of the lines. If they're friendly and helpful and painting is new to you, use their line and ask a lot of questions while you're handing over money![]()
You are using DPLF before any high build primer- I presume that the DPLF does a better job of bonding to the West epoxy (like everyone else, that's what I used for my layups) than would K36 alone?
Correct. My first major glass project (late 80's) started peeling several years later. Actually peel isn't the right word, more like the fill and paint coats separated from the underlying glasswork, in particular in concave body curves. Opening the areas found nothing unusual, just clean, dry separation. Back then I was very busy with a new business and had turned the fill/paint steps over to a body shop. They sprayed a primer/surfacer (K100 as I recall) direct to glass, followed by single stage color.
So, I'm sensitive to the issue. I had a talk with a PPG factory rep during his visit to my local paint shop. He said the best way to ensure maximum adhesion to a glass/epoxy substrate was to spray a coat of DPLF and follow with the K36 "as soon as you can clean up and reload the gun".
Makes sense. Epoxy primers are all about surface adhesion. As for the subsequent coat, the product literature is specific; DPLF is to be recoated before it can fully crosslink, 7 days maximum. You may add 1/2 part reducer or not; without it there isn't a solvent flash time concern prior to recoat.....nor a VOC issue in your regulated area.
BTW, DPLF has a choice of catalyst, 410 or 402. 401 requires a 30 minute induction time prior to spray. Several bulk users in my area use DPLF in their paint process for new aluminum, and they order 401 catalyst. I figure if they are willing to wait on induction time in a production paint process, they have a tested reason. 401 is also specified in the DPLF data sheet for applications over difficult materials like E-coat, rigid plastics and SMC. No downside in my home shop, so I'm using 401. Mix first, spend the 30 minutes on booth and part prep.
Doing my annual, and now after 160 hours, I decide I need to put some of the Cowl Heat Protector that Van's sells inside my cowling. There are a couple of areas where exhaust heat is affecting the glass. Of course, in my haste toward the end of a three year build, I did not do any prep to the inside of the cowl. My engine runs pretty clean, but like any, there is some oil residue, and the adhesive won't even come close to sticking to the cleanest areas, let alone those affected portions.
1. My advise to those of you at that point in the build, take the time, seal and paint the interior of your cowling and do use the aluminum heat protector.
2. Any advise (from you crafty glass people) now, how I can rectify this situation? I am concerned that adding a coat of epoxy to the cowl, despite my best effort at prepping the cowl, would now be futile, as so much oil residue is impregnated into the rough glass. I am reluctant to use an aggressive solvent and risk making what is mostly a cosmetic issue into a structural one.
