OK, pop the popcorn.
I have heard several differing opinions on where you should set your throttle and CS prop handle when securing the engine after an inflight failure with no restart. Some of these opinions are delivered with accompanying bulged temple veins, rounded fists, and an occasional table smack for emphasis.
So knowing this may be an emotional subject, I’d like to know your recommendations. Calmly, now.
Throttle full forward (open) or full back (closed/idle)? One pilot said full forward would open all internal “valves”, but wouldn’t that also set up a cylinder or two to try and compress that air? Or go idle to secure the engine completely?
Prop handle full forward (flat pitch) or full aft (streamlined, near-feathered)? Flat pitch creates frontal drag. Prop handle full aft streamlines the prop reducing drag: However, one pilot said it may allow the prop to turn, which can decrease airspeed and disrupt airflow across the tail. Will this matter with no hydraulic oil pressure to move the prop?
Fights on.
Fights on.
