B bob888 Well Known Member Sponsor Feb 26, 2019 #1 Is there a need to recheck the torque on engine mount bolts at the annual condition inspection as a metter of routine?
L lr172 Legacy Member Feb 26, 2019 #2 Bolts are tightened against a steel sleeve in the isolator and not rubber. no unique reason to check torque on these bolts over any other bolt on the engine or mount, in my opinion.
G gasman Well Known Member Friend Feb 26, 2019 #3 Check the motor mount to firewall bolts within the first 300 hours.
