Alan Carroll
I don't think the root cause is a gear manufacturing/hardness problem. Since you don't have mags installed the right mag idler gear could be ringing on every power pulse and beating the crankshaft gear to death. I would remove the idler gear on the right side since it no longer serves a purpose. The damage to the gear appears to be consistent with this sort of thing and maybe that's why there's no metal being shed by the gear. Essentially the crankshaft gear could be getting shot peened to death. Which would explain the lack of metal in the filter.
Bob,
Unless the two gears are of different hardness, shouldn't the idler gear show similar damage? (the same impact force is felt on both surfaces). Also I'm not sure I see how this explains the earlier lack of metal in the filter; it sure looks like there is metal missing from the gear. Are you saying the gear wore down too slowly to produce noticeable metal?
