terrykohler
My engine is an O320-D1A spinning a FP prop. I've got an oil leak coming from under the Accessory Drive Adapter Pad Cover. Likely a failed gasket.
Question: When I replace the gasket, should I use a gasket sealer? Recommended type? Most of the on-line information for sealers tell me that they shouldn't be used with a gasket, just on bare metal, but the Lycoming manual lists a gasket. Recommended practice?
Terry, CFI
RV9A N323TP
Terry, CFI
RV9A N323TP
