O-360-A1F6D
Approximately 4 hours ago I
Had a 0 PSI annunciation for fuel pressure about a minute after swapping tanks to my MoGas tank. Turned on boot pump and swapped to 100LL tank and landed with no issues. I landed, turned off the boost pump and engine pump held pressure fine on the taxi in. Flew .5 home no issues, I concluded maybe winterblend mogas wi the the warmer temps was my issue.
Another couple hours flying and it happened again, 100LL in both tanks. 20 minutes after takeoff I got the 0 PSI Fuel Pressure. Boost pump on and swapped tanks brought the PSI back to normal. After 5 minutes I turned the boost pump off and Fuel Pressure was back to 0 within a minute. Landed and turned the boost pump off, it held fuel pressure on the entire taxi in
Engine ran fine without a stumble, but it was only a couple seconds from 0PSI annunciation to the boost pump on.
I’m used to fuel pumps on cars failing and staying failed, anything else to look for besides the fuel pump?
