wingnutzster
Member
Hiya folks, so I have just installed my engine control knobs (all three plus cabin heat knob) on my panel and sub panel. Having shaped the outside edges of the bracket F-746 to take off the corners and better suit the asthetic of my panel, and then spaced the knobs as best I can with the space available I end up with a very tight fit when applying my hand to the knobs - and I have very small hands. An average sized male would likely not be able to get his hands on the knobs as required for normal operation.
I have a history with the Cessna types and have never encountered this on any of them or any general aviation types I have flown. I searched online for some sort of indication of minimum spacing for the knobs but can't find anything.
Can anyone suggest what this spacing should be? Given the F-746 bracket dimensions I suspect I will have to fabricate a custom, longer bracket that fits the panel to replace this one which in any case has to be redone.
![465874_10150716907570671_541030670_10056270_50244197_o.jpg](/proxy.php?image=http%3A%2F%2Fa1.sphotos.ak.fbcdn.net%2Fhphotos-ak-ash4%2F465874_10150716907570671_541030670_10056270_50244197_o.jpg&hash=a2652b495704c654a9c4539338ffc8eb)
