engine components
Cdenora
Patron
Hello to all A friend and I are about to start an RV12 kit , but we want to anticipate some parts that we will need ,the build will be in Mexico so the airplane will be done using an existing rotax 912 uls engine that we have , but I would like to get it as original as I can to the complete kit that vans sells , so Im missing the radiators , exhaust and stuff like that fiber glass shroud on top of the engine case etc , I asked vans for the power plant kit supply list but didn't really get the answer I wanted or needed , so I would like to see if somebody knows or has the parts list for the power plant kit to see if we can get the parts .
Our plan is to buy everything from vans except the power plant kit , we would like to get only the parts we need .
Would really like to hear somebody´s thoughts on this matter and see if we are not pursuing a really complicated task by going this route .
We are a very long way from the point needing these parts but i would like to know as much as I can thanks
Christian, welcome to the form. We will try to answer your questions if we can.
Go do the web link below and down load Section 46. Review this section and see what parts you will need. Each item in the directions has a part number that you can use to order from Vans. Good Luck!:)
http://www.vansaircraft.com/pdf/revisions/RV-12/Section_46.pdf
As far as fuel lines I recommend:
http://www.aircraftspecialty.com/kitplanehoses/hoses.html
See if Vans will sell you a complete set of plans for the firewall forward sub kit. That will show you just about everything you will need.
John
Thanks for the info i will call and ask them and see if they can sell me the plans for the subkit to get part numbers like oil radiator and water radiator and stuff like that will start doing these small mods
Regards
Christian
