Emergency screw jack fits rv3 thru rv9
bentlr
Member
The issues I had to design into the jack was: if the tire would be flat, off the rim, or just low which involves different length pipe, a wood block and several steps. Three if off rim, two if just flat. One if not flat. Useful for an emergency repair when traveling. (Might also carry a tube repair kit) A patch may not be recommended but it will get you home in a pinch. Use at your own risk. Always take all safety precautions. i.e. proper chocking.
