Scott Will
Went to reverse the power wires on my elevator servo because it ran backwards. I then noticed that the threaded shaft is interfering with the wires I ran to the servo. As you actuate the servo, the threaded rod extends into the hole & snap bushing and it rubs on the wires (thank fully I have the wires protected very, very well and I caught it before anything actually happened).
What are ya'll doing to solve this? I should probably take the elevator off and drill a new hole above or to the side so the threaded rod slides in and out of the prepunched hole Vans put in the spar.
Any ideas?
Thanks!!
Any ideas?
Thanks!!
