Electric fuel pump
Mconner7
A friend just called and the electric fuel pump in his -10 is tripping the breaker intermittently. He called VANS and they are back ordered. Does anyone know the model number and a good source for the fuel injected 540?
Air Flow performance, # 2090255 bet Don has plenty of them.
Assuming you are looking to replace just the pump and not the whole unit. Depends how old it is. The airtex that don used to use on the older setups are no longer made. I just had to replace one on my 6. There is a delphi replacement that is pretty much the same, but about an inch longer. So you either need to make new tubes or send it to don to make them for you. The bends are tight and a challenge to make.
I assume he already checked the fuel line after the pump, just to make sure it's not clogged or restricted? This is just in case. I think the pump is the issue but... things happen
