Yes -- it's very common to have your EGT indication surge higher and then drop to normal in a cyclic fashion, especially while you're leaning. Typical failure of an EGT probe is to go non-linear, especially in the higher temperature range.Just wondering, When an EGT probe is going bad, does it usually quit all together of kind of flicker for a while? sometimes going up and down.
You could, but they're not cheap. They're not hard to replace if they fail one at a time, and the consequences of failure are really more of a nuisance and not necessarily a safety of flight issue. It's really just up to you if you want to replace them all.If one or two are going bad, should all be replaced at the same time?
I have had a 3 EGT probes go bad in 1400 hrs but no CHT probes. I just changed the ones that went bad (not all at the same time or on the same engine). The first thing to check are the crimps. I have had a couple factory crimps that needed re-crimping and things were ok. That's the first thing I do if I see an erratic or unusual very high reading.Troubleshooting this right now, with both an EGT and a CHT sensor (or multiple).
What is the generally expected life of these probes?
My concern is "how do you know they are bad?"You could, but they're not cheap. They're not hard to replace if they fail one at a time, and the consequences of failure are really more of a nuisance and not necessarily a safety of flight issue. It's really just up to you if you want to replace them all.
I don't use the factory connectors, I hate them. I replace with weatherpak connectors. They are a bit bulky, but much better imhoI have had a 3 EGT probes go bad in 1400 hrs but no CHT probes. I just changed the ones that went bad (not all at the same time or on the same engine). The first thing to check are the crimps. I have had a couple factory crimps that needed re-crimping and things were ok. That's the first thing I do if I see an erratic or unusual very high reading.
The easiest way to determine if a probe is bad is to swap it out with a probe from another cylinder. If the bad readings follow the probe, you've pretty much chased that rabbit down the right hole.My concern is "how do you know they are bad?"
If the failure mode is obvious, like it reads 0 or constantly hops around then fine, easy to detect and fix. But what if the failure mode is more subtle, like it starts to read a lower and lower temperature. Would that cause issues when trying to get LoP for example, or does it even matter since we're using differential rather than absolute temperatures?
Yeah that’s great when it’s an obvious behavior but doesn’t work, or doesn’t work as well, if the failure mode is more subtle ie reading hotter or colder as it agesThe easiest way to determine if a probe is bad is to swap it out with a probe from another cylinder. If the bad readings follow the probe, you've pretty much chased that rabbit down the right hole.
All egt and cht temps, oat and oil temp should read really close to the same temperature if sitting in a hangar over night.Yeah that’s great when it’s an obvious behavior but doesn’t work, or doesn’t work as well, if the failure mode is more subtle ie reading hotter or colder as it ages
Yeah, mine does that but when i fly and the temps come up, that’s when i get the erratic readings. That’s why it may be the molex pins. Maybe I will take it out and test it with a blow torch. Heat gun didn’t get it hot enough.All egt and cht temps, oat and oil temp should read really close to the same temperature if sitting in a hangar over night.
