I depends on weather your EGT probe is grounded or not grounded. Grounded probes have the thermocouple junction welded to the probe's outer sheath for faster response times, but can be more susceptible to noise and RF from ground loops. Ungrounded probes are insulated from the sheath, providing immunity from ground loop issues but with a slower response time. My ISSPRO 2-1/4 EGT (Vans Gauge) did the same thing, but my newer UMA EGT with ungrounded probes are "rock solid". Also, using double shielded coax to your VHF antenna should help.
