flyvans.com
hi,
has anyone installed the new eci exp (airmotive engineering) fuel injection system together with an airflow performance fuel pump package?
we ordered the afp pump early on and installed it, only decided on the fuel injection about half a year ago. now the installation manual for the eci injection calls for dual speed pumps, excerpt:
according to Don at AFP their pump can be throttled. They however don't have a voltage vs speed vs fuel pressure table, has anyone experimented/tested on that?
what have other builders done?
if possible, we'd like to stick with the AFP pump and also keep it simple by not plumbing an additional facet pump or the like into the system.
thanks for hints!
kind regards, bernie
4.2 Boost Pump(s)
The AE fuel injection system requires the use of at least one boost pump. AE strongly recommends using a boost pump that produces both a high and low pressure setting, or two boost pumps arranged so that one can produce at least 18 psi fuel pressure for emergencies, and another to produce 3-5 psi for take-off.
thanks for hints!
