Ever measure temps at the battery?I have been running ETX 900 for several years in my -14A and no issues and no special cooling ducting.
Curious where you have your temperature sensor located. I can move mine around (and have) and see nothing close to this where my battery is located (stock 14A location, upper co-pilot side top of firewall). I do measure temps much higher lower on the FWF behind the engine and exhaust manifold. My upper Earth X battery is still in my airframe after 700 hrs. and 9 years since purchase, my battery located lower on the firewall (Where it sees temps in the 160 F range no blast tube and 145 with a blast tube) was replaced after 500 hrs. and 7 years after purchase. I replaced it when it failed the 80% ampacity test at CI. After shutdown I have seen temps increase 15F if I don't open the oil door and ~ 5 F if I open the door. Cathy at Earth X told me it is temperature related and although a blast tube is not functional with the engine off it does reduce temps for the majority of the time the engine is running.I have seen 182 degrees under the cowl on a hot day after a short stop, before starting engine. The EarthX (or any type of battery) probably accelerates aging when this happens. The problem is that there is no blast air available when the battery needs it most.
Correct, this is the full published spec:I have an EarthX 680c in the lightweight skeleton battery box on my RV7. I wondered about this so I put a cheap thermometer sticker on it and saw a max of 150f, presumably when it heat soaked after shutdown. That was during summer when OAT was regularly hitting 100 degrees and it was probably around 110 in my old steel T hangar with the sun hitting it. I also have no idea how accurate those little stickers are so who knows.
I think I recall that 150 is the max according to EarthX, but it sat on the shelf for about a year and it's been in the plane now for close to 2 years and still going strong.
I shoved a multi meter thermocouple from below while on the ground. Also the EFIS reported CHTs at 300 after being parked for ~15 min and oil - 180. That was a lot of heat radiating from the engine back to the firewall where the battery is mounted, with dark paint on top cowl under the sun and no wind, OAT 100+. I know this was not very scientific since i didnt measure the battery temp directly, but still pretty harsh conditions for delivering cranking amps and then recharging at high rate while taxiing with little airflow . I don't fly often at these temps and my EarthX still has nearly full capacity after a few years of use.Curious where you have your temperature sensor located.
I thought the BMS kept them from overheating?Anybody with an EarthX 900 find it necessary to add cooling ducts for a firewall forward installation?
The BMS will "throw a code" when the internal temperature hits >85°C (185°F) -- 2 sec on, 2 sec off, repeats.I thought the BMS kept them from overheating?
The 5/8 blast tube would come off the back of the rear baffle so would not be ambient. I've measured temps almost everywhere FWF but not the rear baffle. Possibly someone else has? (And I used a blast tube in Ohio winters and no downside effect on my ETX900 mounted FWF, 8 yrs and still passes the 80% ampacity test)We have a Earthx ETX680 attached to the firewall in a slightly modified (bended) standard battery box provided in the kit (Vans) and had an oberheat warning during a summer flight. After insulating the battery like rockitdoc did in post #15, the issue never came up again. But e thermal sticker shows max temp of 150°F on the battery, probably after shutdown… we don‘t have a cooling duct, that would be the next step. Although I am not sure if it‘s really healthy to blow temperatures in the 0°F range onto the battery on a cold winter day ober the Alps…
Sorry for the dumb question, but where are you pointing the blast tube?The 5/8 blast tube would come off the back of the rear baffle so would not be ambient. I've measured temps almost everywhere FWF but not the rear baffle. Possibly someone else has? (And I used a blast tube in Ohio winters and no downside effect on my ETX900 mounted FWF, 8 yrs and still passes the 80% ampacity test)
it would be interesting to plot charge/discharge current over the same chart. there may be very little current flowing through the battery in normal flight since it only acts as a buffer to smooth out alternator ripple. i have blast air pointing to the mags and that creates some flow over the battery as well which may be all it needs.Since I have a linear servo actuating my oil door, I pointed the blast tube at a spot, so the linear actuator and the front of the battery box are hit with cooler air. My ring thermocouple is located behind the battery box between the firewall and battery. This is the reading last summer in Florida.
Note OAT is in C but displayed on the G3X in F. Not sure why.
I have a temp probe about an inch away from it and usually read anywhere between 120F to 145F depending on the OAT. It has never got to the temp that would trigger the warning of the battery. This is without any cooling duct.Ever measure temps at the battery?
