EarthX battery
Normally my “green” is 13.6 to 14.3 volts. Anything above and below probably user preference. Since I have a set-able voltage regulator (B&C) I have it at 14.2 both batteries so 14.3 appropriate. You can charge these batteries up to 14.6 and if so probably 14.7 more in line with “green settings”.
Thank you!
Earth x has changed their case dimensions
Earth x has changed their case dimensions. Recently purchased an ETX900 for our RV7. They have slimmed down the battery case so that it fits the stock battery box now.
