Hey guys, been lurking on here for a couple years while getting an early 4 finished up that a friend started in the 80's I believe. Have a few bugs to work out, but it is finally in the air. I have tried searching and have found some of them but am hoping you could send me to a thread with a comprehensive list of changes from the older kits to now. Thank you!
Built, flew RV-4 for 11 yrs early RV-4. There was a book that compiled all the RViator's. Van's monthly news letter. It was something like 20 yrs or 25 yrs of RViator. It will be a wealth of information. (
RESPECT Vne. If you are over 10,000 feet, point it nose down, fast descent, Vne is TRUE not indicated. All RV's can flutter if you exceed limits.)
Depending on year kit was produced may determine kind of fiberglass, cowl, fairings, vinyl-ester (no core), gel coat. Van updated glass parts for all RV's.
There was the short gear and later longer gear versions of the RV-4. New engine mount for longer gear.
There were old wheel pants, mid-gen two piece, than latest greatest bigger two piece (now standard for +20 yrs).
There was an old air scoop and unfiltered airbox. The FAB (Filtered Air Box) came next and standard for +20yrs. Id unfiltered change that ASAP.
Second for newer RV's RV-8 and on, if you are registered with Van's, with serial number/customer number, you can log in, look for all the service bulletins, service letters, plans updates. See if you can look up this data, give Van's a call. I am sure RV-3/RV-4/RV-6 have historical data you can look up with Van's.
Other than that there is a lot in common with RV-6 and later RV's.
