For some reason I no longer get a button for heading, and also no pitch choice other than “level”.
Has anyone had this problem and any suggestion?
Cheers.
You may have inadvertently enabled "Single Axis Operation". Depending on if you are using the "Simplified" Mode or the "Expert" Mode of the AP, see "Single Axis Operation" on pages 8-14 and 8-26, respectively, of the SkyView Classic / Touch Pilot’s User Guide – Revision AH:
Yes you’re right…discovered I put myself in the “simplified” mode due to random button pushing!
It helps to fly more than once per month to know how to operate one’s avionics!
