ben barron
My roll servo stopped working on my last flight. Jeff at Dynon gave ma a simple test to confirm it was a failed shear screw, which I did. I now need to install a new screw. Has anyone out there done this? Can it be done in place? The new screw goes in a new hole. Will the servo re-set it self as the arm will be in a different location to align with the new screw?
Dynon sends out (at no cost) a new screw when you reach out and then fill out a form. Www.dyninavioniocs.com/guides/servo_shear_screw_replacement_instructions rev_E.pdf
