OK so I have a three day weekend and want to work on the wiring for my two Dynon panels and have questions, but dynes is closed today so I turn to you guys. The question is I have two SV 700 screens and I need to know if both harnesses are tied together for the serial ports, contact inputs, audio out/in and the SV GPS 250? One panel will be used as a PFD and the other panel will be used as the EMS. I plan to use terminal strips for the connections so do I just land both wires (one from each harness) to the same screw on the Dynon side of the strip? I have read the install manual twice and think the this is the way to do it but just want to make sure, not a electrical person.
Do I need to go from the EMS module to both SV 700 or just one for screen redundancy?
Also I have a Garmin XL 250 and a Garmin 496 as a GPS source, is there any advantage of using the Dynon GPS-250, besides triple redundancy?
I have tried the Dynon forums but those guys talk in a foreign language I don?t understand.
Thanks for any help
Thanks for any help
