I got this message when beginning to configure my Skyview system today. Steps to figure it out:
1. Continuity good in D9 network cable from HDX1100 PFD to Network Hub
2. Confirmed all network D9 cables wired correctly and continuity good elsewhere in network
3. D9 network connection from HDX1100 PFD to ADAHRS confirmed correct
4. Switched monitors from left to right in case it was the D9 connection on the monitor itself. Same issue with both HDX1100's
My ADAHRS is not connected, though, since wings are disconnected. So one part of the network is open, ie, from the PFD to the ADAHRS. But, if this were the problem, wouldn't I get a message that Data Line 1 also was faulty?
Also, my Com-Panel doesn't show up on the list of avionics. It did earlier today, but now, it does not. Hmmm.
Any help appreciated. This has me flummoxed, so far.
