pazmanyflyer
For you RV-7 tippers that installed the Dynon GPS-2020 antenna, which connector did you use for the 4 wire connection? I want to be able to disconnect quickly for canopy removal or maintenance so the heat shrink over pins method is not an attractive method for me in the case. I'm going to locate mine front and center on top of the glare shield under the canopy.
