I had the same issue with a D6. I cut the wire to the audio panel (intercom), used alligator clips to insert a series resistor. Tried 1K, 3K, 5K ohms, etc., until the volume was about right. Soldered the correct resistor in series, added a stiff insulated piece of wire plus shrink wrap for support.
