USB drives are not identified at the ports at the back of the EFIS. Unable to load files, the option is greyed out. Tried multiple USB drives, all of which work correctly on my backup display. I've replaced the extension to the USB port on the EFIS. Next, I'll check if the 5V is present at the port. Display Hardware Information reports Internal Voltages: OK so the 5V output is probably correct. Any thoughts on debugging this USB communication problem?
