Folks some Dynon newbie question, I hope some with Dynon experience may help me with some basics here.
- With and Skyview Classic how many external boxes is needed ?
Can it run out from the box and only need the interface for the engine monitor ? (If engine wanted)
(Sure I understand, temp. pitot. )
Maybe some can explain the absolutely minimum here ?
Same question regards the EFIS D10
I have the D10 engine monitoring (not installed) for 6 cylinder with all the probes.
May this unit transfer the signals to the skyview like the stand alone interface ?
If not, may I use the probes to the stand alone interface, or do the Skyview require its own probes.
May this D10 unit be set up for 4 cylinder ?
