Jetguy
DYNON HOW TO!
Richard,
Step 1 Install your USB/Serial cable that came with your D180, Don't use the Windows driver disk that comes with the cable, go here http://dynonavionics.com/docs/support_software.html and down load the driver for your Version windows system from under the header, "USB-Serial Converter Drivers".
Step 2 Go here http://dynonavionics.com/docs/support_software.html and down load and install the "Dynon Product Support Program".
Step 3 Connect your computer to your D-180 through the provided serial port. Turn on the Master switch and the Avionics switch and the Auto Pilot switch. Open the "Dynon Product Support Program", Under "Choose Product" Tab Click on the down arrow and select, "FlightDEK-D180/Autopilot". Then go to the, "Choose Action"' Tab. Choose "Detect Firmware Version" then select Go.
Ok if everything works correctly you should be able see all your different pieces of hardware and what version software is installed each one.
Richard,
