I recently bought a Thorp T18. It has dual Pmags on an O320 B1b. The previous builder rebuilt the engine but did not keep records well and his family may have thrown out the logbooks not realizing what they were or their value.
Anyhow I know it is 160HP. From what I understand 160hp can have either 8.5:1 or 9:1 compression pistons. I previously read that premium no ethanol auto fuel can be used with 8.5:1 or less compression but should not be used with the 9:1 pistons.
My question is: with dual electronic ignition does the variable timing offer additional protection from detonation to allow even 9:1 to used auto fuel?
From what I have read so far. The only way to determine if I have 8.5 or 9 to one pistons is to pull the cylinder and look at the part number that is located on the bottom of the piston.
I really don’t want to pull a cylinder just for this knowledge of there is no other reason to pull the cylinder.
The previous owner and owners son only burned 100LL as it was convenient at the airport.
Is it OK to burn auto fuel? Or is there another way to determine which pistons I actually have without pulling a cylinder?
It would be nice to burn auto fuel to save money. But not if it is unsafe or would do damage to the engine.
