Because you will be drilling the hole and cleaning up the threads after the cadmium plating operation, the areas where you remove the yellow cad plating will corrode much faster than a standard AN7-21 bolt. Whether or not this matters is a choice only you can make.
I have done many this way. Just have to be careful the drill bit goes straight, the small ones drift off easily. I drilled each side of the nut separately for that reason.
