double flush specifications, 21-10 step 3
dbhill916
Patron
Hi all,
I just finished squeezing the double flush rivets called out in 21-10 step 3 (sandwiching a bearing for the Control Column Mount Assembly). No matter how hard I squeeze, I can't get the shop head flush with the surface. I'm about 1/16" proud.
Question #1: What are the specifications for the shop head in such a case?
Question #2: Is it acceptable to micro shave the shop head to meet spec?
Question #3: Where would I find the equipment to do such shaving?
Thanks in advance,
-dbh
leave em stick up and file them in the end if you need clearance.as long as they deformed to fill the countersink they are doing their job.
