Door Hinge Pins /Stainless?
raabs
Any issue with using stainless clevis pins or dowels for the door hing pins to help avoid potantial rust?
Also since my hinges are a bit sloppy (too much play), I?m thinking about a tiny bit oversized pin.
Don?t know about compatibility issues with Stainless Bolts in the hinges, but definitely a thicker bolt/pin is a good idea. The standard bolt supplied as you say gives a lot of play and by the time that movement is translated down to the bottom of the door to the pin area it gives potentially a lot of slop/sideways movement. As well as putting in thicker hinge pins/bolts I fitted the after market Aluminium Door guides which positively centre the doors as they close. As far as potential rust at the hinges, a small hole in the center of the hinge and on the top when the doors are fully opened for the introduction of corrosionX or similar I reckon is not a bad idea.
Stainless steel is not magnetic. If you are using the magnetic door sensors it might not be a good choice.
-Marc
Todd was the prize. Yes, I'm referring to the four top door hinges and the pins/cutoff bolts that are used in them.
To answer your question I think its a non-issue. If you're still concerned coat the bolts with grease or your favorite corrosion inhibiter and press on. As for the slop, have you completed mounting the doors 100% -- seals, struts, and latching pins? If not, I'd stick to the stock bolts until you've got them totally mounted. Your slop issue might eliminate itself.
door wiggle
I had machined pins made out of quality steel to take the slop out of the hinges. The slop you mention in the hinge will translated down the door and make an even sloppier fitting door (wiggle) just what you don't need. I have over 1,000 hrs on my plane and have no issues in that time as one data point.
Don Orrick
N410JA
40010
We eliminated most of hinge slop by simply installing two AN960-10L washers between the hinge halves. 0.032 thick and eliminated almost all play in the hinges. Cost $0.16.
Washers helped remove some of the horizontal slop. I fabricated temp oversized pins today and removed the rest of the vertical slop that was due to the AN3 bolt diameter being a bit small.
With all the initial slop, the door was moving around to much to do a quality door fitting. With slop removed, the door was easier to trim and opens and closes in the same spot every time. I will have permanent hinge pins machined next week.
Between the struts and (when closed), the seals, there's enough preload so the stock hinges and pins don't rattle around.
I placed/drilled my hinges so that the inner and outer hinges eyes create a light tension on each other in the horizontal axis (each canopy mounted hinge half is pushing firmly outboard against the other hinge half). This seems to give me a very reliable closing alignment. I can't see how reduced clearance in the vertical axis would make it any better. The key to door alignment is to stop horizontal pivoting of one hinge half relative to the other. tightly spaced eyelets (i.e. no space for hinge half to pivot) or tight clearance pins should achieve the same objective.
Larry
hinge pins
Not all that familiar with the 10 but would it not be possible to tighten the knukle?
Whicher path you take, it's probably a good idea to use some sort of lube.
For those of you who want to use Stainless on the latch side:
Most Stainless IS magnetic. 300 series is generally not, unless cold worked, wherasl 400 is magnetic. There are many other types of stainless; 17-4ph, etc.
A simple reference here: https://www.fastenal.com/en/75/magnetism-in-stainless-steel-fasteners
Larry
If there is vert slop, the the door can twist a bit if the front is down and the back is up or vice versa. I have over sized pins in now and it's a big nice difference to remove the vertical slop as well as horizontal slop.
Thanks for that. Maybe I will make up a few pins. Do you recall what the diameter was that your machinist cut them to?
EDIT: I just played with my doors and they couldn't be tighter - 0 slop. Not sure if it is because the halves are tight against each other or I got lucky with tiighter tolerance holes. I remember That I had to kiss one of the bolts/pins with sandpaper for it to go in and I don't remember any meaningful slop when installing them (would have made custom pins if they were noticably loose), so likely I have tighter holes.
Larry
