And stick shifts.Ha!
For me that is a huge paradigm shift in engine technology and not attractive.
But I still think cars should come with V-8's.
Sometimes it didn’t:Not too many people are going to be impressed with putting a Rolex into an RV!
I'll stick with Timex. "It takes a beating and comes up ticking!"
You’re right that modifying a flying airplane (with a flying engine) makes the costs look pretty excessive. But for a new build where you have to buy a FWF kit, engine, and Prop, the difference between the Lycoming option and the ROTAX is more liek $20-$25K on a $180K-200K aircraft. In terms of absolute dollars, if you’re counting every singel penny, then years - pretty expensive. If looked at as a delta in the percentage of the total aircrft cost, it is not so far out in left field - if you want something unique and that cruises high and fast…..I guess my problem with the rotax conversion is that the 916is is $50,000. My A&P friend is helping me rebuild an IO-320 which we are going to be able to rebuild for under $30,000. It would have been under $23,000 except for having to replace the crankshaft that ended up having a crack in the oil hole. Even if i decide to put FlyEFII system 32 on it instead of overhauling the mags and carb it will top out around $33,000. You can buy an superior IO-320 for around $36-37K. The 916IS will burn around 5gph and the IO-320 around 7. call it $4.25 for 91 octane fuel which the IO-320 will burn and you are saving about $8.50 per hour. Even at the more expensive end of the IO-320 that is over 1600 hours to break even and more like 2000 for me and the overhaul cost will be higher. I guess it is really hard to swing that extra cost, and i didn't even factor in modification of the airframe costs, when I am trying to keep my costs down. If they could figure out how to get the 916is under $40000 I think it would a lot more palatable
So I am doing a slow build and doing almost everything myself to keep the cost down. My build cost is going to be more like $150,000-160,000 not $180-200K if I had that kind of budget I would be building a 14 or that sling TSI that I test flew at least then you get 4 seats. It was only a couple of years ago that 180-200K was RV-10 moneyYou’re right that modifying a flying airplane (with a flying engine) makes the costs look pretty excessive. But for a new build where you have to buy a FWF kit, engine, and Prop, the difference between the Lycoming option and the ROTAX is more liek $20-$25K on a $180K-200K aircraft. In terms of absolute dollars, if you’re counting every singel penny, then years - pretty expensive. If looked at as a delta in the percentage of the total aircrft cost, it is not so far out in left field - if you want something unique and that cruises high and fast…..
I’ll say I gave it serious consideration as a new project to replace our RV-6 for cross-countries…then this Rocket fell in my lap, and the shop became occupied….
I'm glad to see aircraft designers like Vans look at Rotax and Deltahawk. I think this is the future of aircraft engines. Lycoming is trying with their iE2 but I don't think they will be able to catch up.
Having a few hours behind both Rotax and Lycoming engines I prefer Rotax hands down. No engine temp concerns, easy start, cheap gas, less engine vibration and no oil burn are a few of the things that cause this opinion. Maintenance has not been an issue as I have a great Rotax mechanic on the field. I spend a lot of time with them (we're neighbors) and have the benefit of seeing the airplanes that come in and out of their shop year after year. Incredibly rare to see Rotax have a bad cylinder or compression issues or the other problems that traditional aircraft engines have.
If there was a Rotax option for my RV10 I would have gone that route but so far that's not possible. I went with a Lycoming with EFII system and it's been good but I am also on the Deltahawk list and will swap it out once that becomes available.
The cost is absolutely something to consider but for me the extra cost was worth what I perceive as a better engine.
There is a guy who gives EAA webinar who is also a Rotax certified tech. He said Rotax can easily go over 4000 hours. This isn't a surprise since the said pilot flew his airplane regularly. I think Mike Busch also said the same thing that Lycoming will last way past TBO if we fly our airplane regularly. My hangar neighbor had to replace 5 cylinders on his Bonanza. He flew his for less than 20 hours last year. When doing oil analysis, it came back with metals from sitting too long.I know squat about Rotax engines. How much does a Rotax overhaul cost and where do you get it done? Do they commonly make TBO? How many hours to TBO?
I do know TBO isn't required for our purposes.
Joe
