humptybump
There is an air-facts-journal article on the "changing myths of aviation" and their suggestion to "keep your speed up" on final seems counter productive.
The article points to the need to understand an airplane's deceleration characteristics but it seems to imply the prevelance of the "straight in approach".
I get vectored in "relatively straight" at some Class C airports but not so much at smaller airports. I suspect the majority of "Cessna Pilots" the article refers to are at smaller and often uncontrolled airports.
I would presume a tighter pattern is a better disciple than a faster pattern.
BTW: if my calculations are correct for that diagram, a 3 degree approach with a 600fpm is about 110kts.
![stabilized-approach.jpg](/proxy.php?image=http%3A%2F%2Fsportysnetwork.com%2Fairfacts%2Fwp-content%2Fblogs.dir%2F13%2Ffiles%2F2016%2F02%2Fstabilized-approach.jpg&hash=b9661244e41880d39404533d70ab4acf)
