Anybody know this pin?
It's the pin from one of the wires in a Rotax 912iS connector. The one in which is twist and remove the white pins in page 46is-10 Step 1. The one in which it's anticipated that the pins you're removing my break.
Yep, and when it did, the recoil of my needle nose pliers took out pin #10.
I recognize the connector -- the same ones Vertical Power used in the VP-50 and fortunately I still had those fabulous manuals Marc Ausman provided way back then. So I eventually figured out the proper way to remove the pin on the broken wire.
But now I need to find these pins.
Anyone recognize it, have a part number/description and know a supplier?
