BLittleton
Active Member
Hello all. I apologize if this has been answered a lot, but I cannot find it here on VAF or at aeroelectric.
I'm using the FlyLED position/strobe lights and LED landing/taxi lights in the wingtips with the Archer VOR antennae. If the LED lights are so low voltage compared to others and use shielded wires, can the shielded LED wires go in the same wing conduit as the Archer VORs with shielded coax?
I think I understand that those with older type bulbs would run all the wires separate to minimize noise from the wig wag or strobes getting into the other wires. Is that still an issue with the lower voltage and shielded wires for LEDs?
If coax and shielded light wires still have to be separated, what is the minimum distance?
What about possible magnetometer wire...can that go in the same conduit as the lights?
