We all are learning all the time (we hope)
Well I just do not understand then. I am told by very knowledgeable people in the past that it is torque HP that does the work. Break HP and torque HP are sometimes widely different on the same engine (Ford diesel with 320 break HP and 640 Torque HP) Which is why big trucks are so powerful, and of course gear reduction will increase power to the wheels of a car or truck, so why not to an aircraft prop? You say the PSRU (through gear reduction like gearing down for a hill in a big truck) increases the torque output, and if torque drives the prop???? Maybe I just need time to see it. Not used to the PSRU thing. All my planes have had direct drive Lycoming in them.
Garth the info you got from our fellow members is right. I would just suggest you
Google torque or HP or Horsepower and read some more. Your terminology is a little confused. I understand you are learning. We all where there once.
There is HP and there is Torque, there is no
"Torque HP".
The term is Brake HP (not
"break HP").
Brake Horsepower (bhp) is kind of an old fashion term. Prior to modern electronic, water, eddi current dyno equipment, HP was measured or quantified as the amount of resistance against a flywheel brake. The method is not really used as much, but the term remains in the auto industry. It is just HP. The BRAKE part is not relevant to anything anymore. However measuring HP consistently does have its challenge. All dynos I can think of measure torque and RPM and derive HP.
There are different HP numbers for cars like flywheel HP or Wheel HP, but it's not relevant to our discussion. We have "shaft HP", Prop HP and Thrust HP. The last, Thrust HP, is the equivalent thrust we get to move us. Props are only 75% to 85% efficient. So for ever 10 HP at the prop flange you get 7.5 to 8.5 hp thrust, so for a 180 HP Lyc the best you can expect is about 153 hp thrust (regardless of PSRU or not).
A PSRU does lose HP from input to output, since no PSRU is 100% efficient.
The direct drive Lyc has this advantage of no PSRU power loss, not to mention lighter and no parts to wear or break. If the engine makes most of its HP well above 2,700 rpm, a reduction is needed or prop losses will be high. Lycoming's and Continentals left the PSRU off by designing engines that turn slow enough to make peak HP/torque below 2,700 rpm so the PROP can be directly driven, saving weight, maintence and efficiency loss through a PSRU. There are trade offs, no better. Alternative guys must usually use PSRU's because all the engines they use where originally designed to be used with a transmission or gear box.
The confusion you are having with PSRU is that they DO NOT make more HP they only allow engines to run at higher RPM's to make more HP.
See the equation below, the higher RPM means more HP. However the design of the engine comes in here. It is true the faster you turn the more HP with in limits of the design. At some point an engine runs out of breath and HP (and torque) drops off. The Lyc is designed to make max power at 2,700 rpm. It will continue to make more power the faster you turn it, but the engine's mechanics are not designed for it and efficiency drops off. Engines designed for HIGH rpm (typically have less displacement per cylinder) only start to make significant power (and torque) above 2,700 rpm. As you know red line on some cars and motorcycles are up in the 6,000 to +9,000 range. Some engine are made to run at 100 RPM max power (large diesel) and some run at +15,000 rpm (two stroke race engines).
The PSRU allows higher engine RPM while gearing down the output, so the prop RPM remains in a normal efficient range. Props on planes like ours start loosing efficiency when turned faster than approx 2,700 rpm.
The PSRU itself does not make HP and in fact the mechanics of gear reduction (friction) uses some power. There's no 100% efficient reduction. The only thing it is doing is the "gearing" allows the engine to operate closer to it's peak HP and/or torque rating.
Peak torque and HP don't necessarily occur at the same RPM, but that gets into engine design not PSRU design. The PSRU is just a single gear transmission with no clutch or torque converter if you will. Planes in the end need HP to fly, not torque. HP into a PSRU is slightly less than the output to the prop. However with out a PSRU you could not use small displacement engines that make HP at high RPM's.
The following is the classic HP definition:
Where:
P = Power, hp
N = Rotational shaft speed, rpm
T = Torque, lb-ft
You can solve for Torque from above equation. HP and torque by definition are related. HP is power and Torque is rate of producing HP or torque. In a car TOP SPEED is HP and acceleration or pull is torque. You need both right. For a plane top speed is also HP related not torque, but again the relation of HP and torque are inseparable. You need both and you get both by definition.
No need for me to re-type this info.....here is a
LINK with some good basics.
If PSRU's where so great for plane's, they would all have it. Now to be fair many airplanes do have a gear reduction. Turbines engines turn high RPM and need gear reduction to get the Prop to a reasonable speed. Some Lycs and Continentals tried gear reductions. They really are not popular because of the added weight and maintence. It did make more power for a smaller displacement (by running higher engine RPM), but the solution was simply make the cubic inches bigger and turn the engine slow enough to eliminate the gearing. There is not fuel economy by running a smaller engine faster than a big one slower. (Not totally true but to complicated to discuss here and the difference is small.)
Many of the great big piston radials used a modest ratio gear reduction to make a little more HP by turning the engine a little faster, but the main reason was to keep the large diameter prop tips from going supersonic by turning the prop slower. The props of course where designed for the slower RPM. The gear box on those engines where made from magnesium and still weighted more than your whole RV, well may be a whole Lycoming. On the other hand they made several 1000 hp.
There's no doubt you can make more power by turning faster engine RPM's, but the PSRU is not making power the engine is. Also the problem with PSRU's and tractor airplanes with the engine up front, is the aerodynamic drag, trying to fit the device in the nose of the cowl. Also weight-N-balance CG is to be considered. The PSRU must be engineered for harmonics. Another negative is almost always hydraulic prop activation is not an option, leaving only fixed, ground adjustable or electric props, which cost more and just are not as good as hydraulic constant speed props. If you want to believe PSRU you is all goodness with no negatives and makes more efficiency you can, and you would not be totally wrong. However you're ignoring 1/2 of the equation.
