Dimple question...
rvanstory
Sponsor
Prepping parts for lower skins of fuse. In plans it says to dimple all holes in bulkheads and ribs EXCEPT for the ones where a rib tab is underneath the bulkhead flange. It never says what to do with these, but I assume they want those counter-sunk (even though thickness of metal is marginal at best for CS).
9uP3ELlfgssbu7UWov0GIC-7MERKlG6-kP7e87QsRs2qXtLoYUNgWO8S_ydhK9zhCPs2A7Cz9SBGkQxoTAnAk0oqp1w7S7ATYAIgnT17f-ibtH6N4b0jEIsyI_a-51THfnGNTYgu-H-VmUZcP_dXkMckSZdplxuPhaEyC4IDASuDnfQmaKi9GReEr5e3KZT36aKX0FvExo5EGaq6mRs-VXbhlmn5zVsMlFhqJHRsqhyyLje1FODOM5w5CDI4Oaeqs88JwzSiN5x5zMmqYC-O8laR6EGIIyDAHu5bk-HG_kqGnOAGjROLXgjMvR4iQavaqOB8iBVpLjQA2BrjmQjS3QiwP8O3YsnfNBolUntAdHAGPlZZk2KDb89eBVvuNR81Fbnj4t56XPEko39P-Tc5C3kvbG_h3KYsEq6ZzHOOkHyTiyYNqDIRhiePoRbLfO-ddEEEN0Jbg5brTYxPziE9hLG37HVI7PUiPpzjzF_MTM4eqs0teaE8YTikWtCmS983S0i1O5PFtkB-XRzLEZxx5ReWCbavGzBXEq6_IwJsuP7KWPmzo2IJgvTuUJwMSFQENVzM0Vt_04C7jUxVraFaeSdutYSkX0yRCn714ojWNrp-shQpCH-eJiLkAToqU2uekWQwq8JXmL6tsoLti3hCqncvaCec-ITKcG7NVIaC89TLOw=w1000-h700-no
My question is this for those with greater experience than me. Any reason I can't simply dimple these holes with both pieces of metal together? I tried this on scrap of same thicknesses and see no issues with doing so. Dimple looks good and rivet sits flush. BUT, also don't want an un-intended consequence for doing so.
FTnCBmLJ1s5XkDC_RAYOcT7NswfUdQfRjCra5ZfKID2F4GhJDAMDeuOIUYzVAWPzt-8wpIHgFYvUDA2K0to-WsqnHaHOgcp5jsbYmpSVrhfO5NJframZ-nLzPMvaSpq-xyZjOsJsf-W9bEJk7ucmvY-5vChGxPiGLnEjUeS8xETYnTk5AZ9BdvmKjlSRob5Zbwgc-GQlOaQ_KX_zTFx7bO7c-AiqEbd_Kr2p-xKZPk-o_M485ZvpRTq-cK86iaGlnsMr93TR-qHildolnE-Qsx2fEYavFmyOR-V_pk6Qoe0mww5-BMFRK7lwNhzcZJ7AIwE8vrFwIw_qwV-GC_yzdTB1hgtIK07hwKwH9p6d9f97NHUSsWNhU7s3dD8FdklBEy6GUshEIN42XqrLMCgO1UJKrE2zIpLMITPUR47CDF-pcs_pEJ99owlj3ifBivEYHCb99g3pkjuzYHnSb3KqJlJ9cYTAnggZtix5np6OjYt7B71Udqs-1hrYlgk6bBSzRbSi5MhwwRyc_w5uG_xtPCd6GGtHG0vJRnehWbb0uByY5YquddDzfwqRpWy4yHeaq0aazNMcKsaccJJp-LrCcLqa8n1rE0r8JbSbhFuL-GeFzWQ07odHiaoiJ-s_lp-nDUn1j7ZqPN0gjDjG694JD-qjSwUxfWxnhh84_-2WJRbuHg=w582-h776-no
I'm building an 8, so don't know. Check the rivet callout sheet - they may have you install a different type of rivet here?
Give 'em a phone call - they should answer the phones in a couple of hours.
Good catch on the detail there.
I may be wrong, but if you look to the left side of the page you posted, there is a reference to countersinking those holes. See highlighted portion in pic below:
tx8-ANpVZTfsZwMvHSpflIyhRVcpbWHdIzqZI0guUtN5Dn1zyxRfpNM5kQgomiNyVq-v6KfTM0OS6pcicSfHd_Z5KQQUXM19LF224_nUE4SX2eSwBDaWuT2bv1r1ZriXXgBHfNpd0iIWKy5wQbRl3hMxBDwL08htQZ2J7AjaNBpkJdH_t-C1BNzxDWWIIzN5hCisTrpjj1w1k7ej9RAY1EI-ho0sYShr4khKG__FyQmWV06c4bg29N3gji0n823582adlHqoTTNR2XDUlRdrPYPAxFGyz0OhLpgkIueT9MgJ7NfHPLiLMoP4b-L9c2yy4Pfw_DSXxuYjctMT08bVgJnucAY_AAfElvOpjJwyHTox2Ty1IcoBXjSa1CIsrxONTsJS9GPh7z7Oeng6tsOvtXQjsxgOfW1ca16X_lh1_EymY5pw5jPG_KEm3czs3iCPgg3B9VYAHLypn97B9G5b6MWuBfugZlQLAyUUurB4AMdRU2B6YNZGRLcDDxl7S-7YLtG270Z0omOYgmi3Kwx3NY3AmS7AwRVLnGaAg2ZZaw4B14AY0hVJmZnyaPELzeqplNUxlnq9cOGcqMDeiluiBHNxpoNeveqg3Y54OQhqiGcfhL4lqy4hPicpPzUgeADFSvvyDcIcXRtZPH5lkkWvqTt9or2OyrTz0khy3_ZJqux6sXo=w1210-h339-no
You are correct. These get counter sunk. I think on the next page it shows an arrow pointing to all the tab/bulkead over lay and says to "countersink these holes" I did it on mine and it came out perfect. It seems any place there are 3 piece of metal overlying each other there is a counter sink in the middle piece, with a dimple on the outer most piece.
Thank you for clarification! I usually enjoy showing my ignorance in a public forum. In situations like this, my dad used to say "if that were a snake, he would have bit you"!:)
