dimmer knob on G3X installs
rcarsey
I've noticed during night operations, when the dimmer is set to maybe.. lets say 50%, that the brightness of the avionics (anything that's connected to the dimmer bus) goes up and down very slightly when the strobes are turned on.
Does anyone else experience this? Its subtle and I only recently noticed it.. I'm assuming that there is a very small voltage fluctuation due to the strobes operating.. which in turn, affects the dimmer circuit going to the avionics.
Ground
Its sounds like your strobe ground is running thru the ground for the dimmers too. I would make sure the strobe return current does not go through the same bolts / structure as the dimmers sense circuits on the G3X.
