DavidHarris
My daughter and I recently finished building N912EH, a RV12-iS, and had an first flight with no abnormal behavior.
We took the plane to the FBO to dynamically balance. They found it was at 0.2 (unsure of units) without any weights attached. They said that is good enough, but ideally could be improved to 0.1 or 0.15 with weights.
They found that adding weights caused the balance to change erratically, and were unable to improve the balance. When they removed all weights, the balance was back at 0.2.
They hypothesized that something might be loose (such as an engine mount), but could not say whether there is a safety of flight issue.
Can anybody on this forum comment on whether this may be pointing to a potential safety issue, and whether the balance of 0.2 is adequate?
Thank you,
David Harris
Thank you,
David Harris
