Bill_H
On page 35-04 you install the main gear legs with the brake fittings at the top of the gear legs. You then connect 1289C-L and 1289C-R brake lines to them. (These are the ones from the pedals, not the ones to the calipers.)
1289C-L and R were made back on page 27-05, to very precise lengths. They were secured to the pedals and a precise distance was used to clamp them above the fuel flow sensor. Then they run pretty much straight back to the gear.
As they leave the final bushing, you turn each one to its final destination fitting on the clamp support of the gear leg. Well, mine are about 5 inches and 6 inches too long! I will have to cut off that amount (and redo the press-in fittings on the ends), else they push back and rub on cables and pushrods. When shortened, I see securing them to the floor of that section using some loose cables ties - to ensure they do not rise up and rub against the cables.
Given the very precise measurements - I am surprised at this amount of extra length to be removed. Did anyone else have this experience?
Thanks - Bill H (N412BR reserved).
